Differences between Plextor Premium internal vs. external?
Postby articulate on Thu Aug 12, 2004 5:26 am
I'm considering buying a Premium and putting it in my own external USB 2.0 box. Are there any differences between the internal IDE drive and the Premium-U external drive? Is there any reason there should be problems using the internal drive as an external USB 2.0 device?
articulate
Postby aviationwiz on Thu Aug 12, 2004 7:08 am
Nope, same actual drive. I have mine in an enclosure.
Postby articulate on Thu Aug 12, 2004 8:00 am
Thanks a lot for the quick answer, aviationwiz!
BTW, are you happy w/ the drive's performance - - generally, and in conjunction w/ the USB 2.0 enclosure?
articulate
Postby articulate on Thu Aug 12, 2004 10:45 am
Questions, questions . . .
Is there any difference between the Premium and the Premium T3(A, B, or C) model?
I can't find anything about T3 or possible model differences on the Plextor website . . .
articulate
Postby hoxlund on Thu Aug 12, 2004 9:49 pm
never heard of the T3 model of premium
but when i owned my premium and I too had it in external usb2 enclosure
i was very happy with it, one of the best cd burners ive ever owned
but moved onto bigger and better things, SATA combo drive (16x dvd + 52x32x52x cd-rw)
Postby aviationwiz on Thu Aug 12, 2004 11:32 pm
I haven't heard of a T3 model Premium either...and check my title! 8)
Postby articulate on Fri Aug 13, 2004 6:46 am
Thanks, guys . . .
I guess the T3 is a European model number.
And, aviationwiz, it was a dumb question of me to ask, whether you like your Plex or not . . . :lol:
articulate
