D2D required on destination system
Postby FUBARinSFO on Tue Jan 13, 2009 12:50 am
Hi:
It appears that Drag-to-Disc (therefore Roxio) needs to be installed on a target or destination system in order for that system to read the media. Is that correct? Windows XP can't read a DVD formated with this packet writing software, it appears.
Thank you in advance for your help.
-- Roy Zider
FUBARinSFO
Re: D2D required on destination system
Postby Ian on Tue Jan 13, 2009 2:09 am
I thought XP had a UDF reader built in, but I could be wrong or it doesn't support the version on that disc.
Anyway, give InCD Reader a try. It's free and works with most versions of UDF.
http://www.nero.com/enu/support-nero7-t ... ities.html
