CD Copier Gamers' Edition problem
Postby sherif_shaaban on Mon Aug 18, 2003 9:37 am
Hi....I have CD copier Gamers' Edition V.2 on Win98SE. After I installed it, it ran fine for a couple of weeks, then it made my system freeze whenever I try to access any of my local drives. The solution that I came up with is to uninstall the program: I did it and Windows ran fine again. But I miss the games I used to play using this program, becasue the container files are useless now. I tried to re-install the program and Windows ran fine. Is there a less radical solution to this problem? And is there a version for the program for WinXP? Thanks :)
sherif_shaaban
