Converting Audio CDs to MP3 using NERO 5.5?
Postby Doughnuts on Fri Jun 25, 2004 7:29 pm
Sorry if this is a noob question, but I've can't figure out how to convert audio CD's to Mp3 using NERO 5.5 version O EM 5.5.3.5
Could somebody give this dummy a little help? Thanks
Doughnuts
Postby burninfool on Sat Jun 26, 2004 1:57 am
In Burning Rom(not Express) go to Recorder->Save Track.
You are limited to 30 conversions with OEM,I recommend using
CDex to rip and convert.
BTW..I recommend you update Nero HERE.
Postby Doughnuts on Sun Sep 05, 2004 4:41 pm
Thanks a lot, burninfool.
I used Nero to burn 30 tracks, and then decided to be sneaky. I uninstalled and then reinstalled Nero, thinking that I could then get another 30 tracks out of it. Unfortunately, they must have some other counter because it didn't work. Doh.
On to CDex...
Doughnuts
Postby CCampbell on Sun Sep 05, 2004 11:09 pm
You can also use the below link to download the free MP3Lame encoder plugin to use with Nero to create MP3 files.
But CDex is a good program, too. :)
http://neroplugins.cd-rw.org/
