connection issue question
Postby coonsanders on Mon Jan 06, 2014 9:53 pm
hi
whats the proper way to connect your turntable though your amp into your computer?this is driving me nuts..sort of..lol
lenny
coonsanders
Re: connection issue question
Postby Ian on Mon Jan 06, 2014 10:51 pm
What input/outputs do your amp and computer have?
Postby redk9258 on Tue Jan 07, 2014 8:18 pm
You were talking about 78 RPM records the other day. Is that what you are recording? On any account. you will need to have the audio from the turntable properly EQ'd (and pre-amped) before it is sent to the PC. If you have it connected to a stereo receiver, then use the LINE OUT, TAPE OUT, or REC OUT to go to your sound card. This is what I do when I record music. I record from LP's / 45's only, not 78's. If you are recording 78's they require a special stylus and I'm pretty sure different EQ than LP's / 45's.
redk9258
Postby coonsanders on Tue Jan 07, 2014 8:23 pm
Thanks but this guys helping me
Lenny
coonsanders
