CDR-W And DVD drive seen but wont work???????HELP
Postby NeWcS on Fri Dec 06, 2002 10:44 pm
All of a sudden both my Liteon 40125s and my 10x dvd drive wont work. Both are found by windows(XP Pro) but with an explanation mark next to them. When I goto properties it says
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
I tried to uninstall both and and reboot. Windows found um again but with the same prob. Also, both drives are on diffrent IDE channels. One is on IDE2 and the other is on a PCI IDE card. I tried to reinstall the drivers but it got: Windows copuld not find a better driver......blah blah blah
I also tried del all registry entrys in regueads to these 2 but didnt do anything.
Can anyone help. Thanx
NeWcS
Postby liteoncrasher on Sat Dec 07, 2002 8:43 am
Try this link:
http://www.dougknox.com/xp/scripts_desc ... vd_fix.htm
I had a similar problem and this fix worked perfectly.
liteoncrasher
Postby liteoncrasher on Sat Dec 07, 2002 8:46 am
And if this fix doesn't work well enouh for you, type cdgone into google and look at some of the links.. :wink:
liteoncrasher
Postby NeWcS on Sat Dec 07, 2002 9:10 am
Thanx for the replys. Ill give your suggestions a try tonight when I get home and let ya know how it went.
Thanx again
NeWcS
Postby NeWcS on Sat Dec 07, 2002 10:52 am
liteoncrasher wrote:Try this link:
THANK YOU SO MUCH!!!!! I d/l'ed the file and ran it and then rebooted. It didnt work at first. I then uninstalled the the drives and ran the .exe, rebooted and BOOM! It workd!!!!
I was having bad dreams of having to re-install Windows!!!
Thanx again!
NeWcS
