Can't get the Search engine to work.
Postby HeartBurn on Tue Nov 19, 2002 1:00 pm
Is there a trick to turning on the CDRLabs Search function? No matter what I enter all I get is "No topics or posts met your search criteria." I'm trying to locate the software that allows me to backup the firmware of a new burner before I try to update it. Thanks
R/C Airplanes Forever !
HeartBurn
Postby Ian on Tue Nov 19, 2002 1:02 pm
You're right. I'll let Socheat know.
btw.. that util is MTKFlash. it only works with drives that have a Mediatek chipset though.
Postby cfitz on Tue Nov 19, 2002 1:17 pm
This is a multi-part problem.
1. When the upgrade to 2.0.3 was performed, the index to pre-update posts was lost and not regenerated, so straight searches will not return any hits for pre-update posts. A work around is to append the * wild-card character to each term you wish to find. This apparently forces the search engine to skip the index and search the text directly - slower and less efficient, but it will find older posts.
2. Posts made after the upgrade have been indexed, so non-wildcard searches for 'any terms' will return hits on the newer posts.
3. Searches for 'all terms' rarely return any hits under any circumstances - I think the list of non-indexed terms may be too broad. For example, a search for 'regenerated' AND 'circumstances' will return this post, but not a search for 'return' AND 'circumstances'.
<edit - update 'all terms' search info>
Postby cfitz on Tue Nov 19, 2002 1:20 pm
By the way, Heartburn, you can find mtkflash (and a utility to make a DOS boot disk so you can run mtkflash) here:
http://mand.tmfweb.nl/binaries.htm
Postby HeartBurn on Tue Nov 19, 2002 1:36 pm
Thanks guys for the comeback. I'll be helping a friend install his new TDK model 4800B and from what I have read here on the forum is that I should back up the firmware first. Now I have to find out if it able to be backed up. Mediatek chipset installed? We'll have to find out. :lol: Thanks again.
Heartburn
HeartBurn
Postby cfitz on Tue Nov 19, 2002 1:51 pm
According to Ian's review ( http://www.cdrlabs.com/reviews/index.ph ... e=Features ), the 4800B is based on a LiteOn drive, so it uses the MediaTek chipset, and you should be able to back it up.
Postby HeartBurn on Tue Nov 19, 2002 1:55 pm
Many thanks cfitz, looks like Im off and running. Appreciate the help.
HeartBurn
