I don't have any problem at all with CDR's, but I can't for the life of me get the burner to finalize a CDRW. I get "Could not perform fixation" with Nero. I've also tried Easy CD Creator Platinum, but same results, a wasted CDRW.
I've used this approach: Start>Control Panel>Admin Tools>Services>IMAPI CD-Burning COM Service>General Tab>Startup type>Disabled (was in “Manual”). Also tried it in "Automatic", but neither worked.
I've cleaned the lens with a laser disk cleaner.
I tried different manufacturer's products, changed the burn speed, changed the transfer to PIO instead of DMA, even swapped the drive to the secondary IDE and set it to Master.
This one's got me stumped. My only thoughts are that the NEW drive is bad, but it does burn CDR's flawlessly.
Strange.
I really am out of ideas.
Thanks in advance for any other suggestions.
EagleFire out......
