Do I buy a Sony or Pioneer Burner???HELP!!
Postby k9tpr on Fri Nov 28, 2003 12:28 pm
Hi,
I am in the market for a DVD burner. I have been looking at the Sony DRU-510a and the Pioneer DVR-AO6.
I just returned a LiteOn LDW-411s that gave me too many headaches.
I would like to back up movies (XBOX Compatable), PC Games and XBOX games. I currently have DVD XCOPY Xpress and DVD Wizard Pro software.
Can someone please help me with my decision and the pros and cons of these drives? Or if there is another drive I should be looking at.
Any help would be greatly appreciated.
k9tpr
Postby aviationwiz on Fri Nov 28, 2003 12:30 pm
I have not used either drive, but a lot of people find the Pioneer A06 to be one of the best DVD Burners around. It burns fast, is a quality writer, and is very good from what I hear. I don't think it has any big compatibility problems with anything.
Postby hoxlund on Fri Nov 28, 2003 1:22 pm
go for the true pioneer DVR-106 or the oem memorex which you can in turn flash to true pioneer dvr-106d
owned it, loved it, just got a free swap out with plextor 708a 8x dvd burner
Postby k9tpr on Fri Nov 28, 2003 2:10 pm
Thanks for the input.
I was edging toward the Pioneer however the reviews I have read say that it mtends to be slower that others.
Also, what is the difference between the 106 and A06?
k9tpr
Postby dodecahedron on Fri Nov 28, 2003 2:23 pm
A06 - retail
106 - OEM
it's the same drive.
Postby hoxlund on Fri Nov 28, 2003 2:38 pm
sorry i should have included that, thx dodech
Postby k9tpr on Fri Nov 28, 2003 2:57 pm
Thanks,
Does the 106 come with the same software as the A06 or is it just a bare drive?
k9tpr
Postby hoxlund on Fri Nov 28, 2003 3:47 pm
depends on who you buy and what the description says
some 106's come with software, no software
cable, no cable
all depends on who you buy from
Postby BMR on Fri Nov 28, 2003 4:01 pm
aviationwiz wrote:I have not used either drive, but a lot of people find the Pioneer A06 to be one of the best DVD Burners around. It burns fast, is a quality writer, and is very good from what I hear. I don't think it has any big compatibility problems with anything.
Wow ! love the new avatar Aviationwiz !!
BMR
This guy's name is "Snoopy". He keeps me company while I am online.
BMR
Postby MonteLDS on Fri Nov 28, 2003 4:05 pm
i think the Pioneer reads DVDs faster. i mean come on Sony only allows 2x :(
MonteLDS
Postby hoxlund on Fri Nov 28, 2003 4:07 pm
your correct on that, my pioneer ripped at 12x
Postby k9tpr on Fri Nov 28, 2003 4:15 pm
Thanks everyone,
I just found an A06 at eCOST.com for 119.99 after rebate.
Not bad.
Hopefully I will have better luck with this than I did with the LiteOn 411s I returned.
Thanks again for the input!!
k9tpr
Postby hoxlund on Fri Nov 28, 2003 4:26 pm
i think your gonna be very happy
little words of advice:
www.dvdshrink.info - Movie Ripping/Compression
www.nero.com - CD/DVD Burning Software
Postby Mystery Man on Fri Nov 28, 2003 9:43 pm
Yep i agree with hoxlund, I got the pioneer 106 and use both those two progs. Tho i only use the drive for the actual burning. Reading ripping & preparing i do that with my liteon 16x dvd rom because for ripping its more than twice as quick. The pioneer is slow for ripping dvd's.
I also sometimes use dvd x copy express. The length of time that prog goes from beginning of preperation to finishing the dvd movie burn is much less than dvdshrink. That prog does the burning too. Quality is just as good.
Mystery Man
Postby treemana on Fri Nov 28, 2003 10:52 pm
I own a Pioneer A06 that I've been very happy with.
The bundled software included:
Nero Express 5.5
Ulead MovieFactory2
Ulead VideoStudio7
SA Packet Writing (Haven't used this one).
I've been pretty happy with the included software.
The software included with the 106 would depend on which company bundled it. For example, the Memorex drive comes with Roxio Easy CD/DVD creator 6 as the burning software.
I used to be indecisive, but now I'm not so sure...
treemana
Postby hoxlund on Sat Nov 29, 2003 1:14 am
it did? haha never opened it, used nero and dvd shrink
Postby k9tpr on Sat Dec 06, 2003 11:42 am
Just got the AO6!!!
WORKS PERFECT....5 burns with no coasters.
Thanks Everyone.
k9tpr
Postby hoxlund on Sat Dec 06, 2003 12:00 pm
good to hear, just make sure you update the firmware:
http://www.pioneeraus.com.au/multimedia ... _fw107.zip
Postby VEFF on Sat Dec 06, 2003 12:37 pm
I see you bought the 106.
Both the Pioneer 106 and Sony 510A are great DVD burners, so you couldn't have gone wrong with either one.
I used to own a Sony DRU-500A; I only sold it (along with my other 2 DVD burners) to uopgrade to 8X, otherwise I would still be using it now...
Enjoy!
Burners only:
Pioneer DVR-115D
Pioneer DVR-111D
Plextor PX-716A TLA0304
Plextor PX-716A same TLA
LiteOn 52246S 52X CD-RW
LiteOn 52246S (another)
LiteOn 52327S 52X CD-RW
TDK 40X USB 2.0 CD-RW
TEAC CD-W540E 40X CD-RW
VEFF
Postby TeknoJnky on Tue Dec 09, 2003 1:59 pm
Think I'm gonna buy an external pioneer with firewire, can anyone recommend their favorite site to get one?
TeknoJnky
Postby hoxlund on Tue Dec 09, 2003 2:13 pm
just buy an external usb or firewire case along with the internal pioneer
heres link to external firewire case:
http://www.newegg.com/app/viewProductDe ... archdepa=1
but for $10 more you can get the usb2 + firewire case:
im using the usb case made from them, bought it from newegg, im using my JLMS 166s dvd-rom drive in it, works exactly the same as if it were in my computer
Postby David on Tue Dec 09, 2003 2:24 pm
The Firewire case huxlund linked to is the one I am using.
No problmes with any burners just a problme which was fixed with a firmware modifcation on a dvd-rom drive.
This thread might also be of some help.
David
Postby TeknoJnky on Tue Dec 09, 2003 2:46 pm
Nice links, thanks... currently looking @ http://www.coolerexpress.com/exuspidvdvso.html
179 with nero + shipping
will do some more shopping see if I can get an internal + usb/firewire box for any less..
TeknoJnky
Postby hoxlund on Tue Dec 09, 2003 2:52 pm
yeah thats not to bad of price
just go to www.resellerratings.com to see if that site is respectable
Postby kain976 on Mon Dec 22, 2003 10:52 pm
I have an A06 and am having a hard time finding media that will burn 4x.
Ive tried leda, memorex, neon & matrix. next I will try ritek. anyone know of some others that work?
kain976
