burning speed for audio cds
Postby sonicman on Sat Oct 22, 2005 9:16 am
hi there,
is it true that its better to write audio cds at the lower speed possible, regarding jitter & better burn??
till know with my old plextor i was writing at X4 all my audio cds & i was pretty happy with the results. but know my new dvdr NEC nd3540 the lower cd writing speed it has is X8.
is this a serious problem for writing quality audio cds? should i try to find a dvdr with a X4 cd writing speed?
any advice will be really appreciated!!
sonicman
Postby dodecahedron on Sat Oct 22, 2005 9:39 am
why don't you try one at 8x and see how you like the result ?
it is getting more and more difficult to find drives that burn very slowly.
Postby hoxlund on Sat Oct 22, 2005 1:17 pm
no drive built within the last 2 years is going to burn cds at 4x by default you'll have to tell the software program before you start burning to burn that slow
i usually do my audio cds at 16x in my plextor 716 drive with TY media
Postby SkaarjMaster on Mon Oct 24, 2005 8:19 am
I burn my audio CDs at 8X using TY media and my Lite-On LDW-851S DVD burner, so that I have a better chance of them playing in my car CD player. I don't label them with label makers either anymore. All this is per advice in this forum. 8) I'm sure I could burn them at 16X without any problems, but I'll just stick with 8X for audio CDs for now. Based on this, I would have to say to not worry about burning at 8X on your NEC. :D
SkaarjMaster
Postby MediumRare on Tue Oct 25, 2005 3:40 pm
I burn my audio CD's at 32x or higher and have never had compatiblity problems. :D
Mind you, I use quality media (usually Verbatim DataLifePlus). Also, I don't have a CD-player in my car, but all discs I've tried in the rental cars I get for business trips have worked just fine.
Postby dodecahedron on Tue Oct 25, 2005 3:51 pm
MediumRare wrote:I burn my audio CD's at 32x or higher and have never had compatiblity problems. :D
what's "and higher" ?
Postby MediumRare on Tue Oct 25, 2005 4:21 pm
Mostly I use 40x, sometimes 48x (max on my LTR-48245S), almost never slower than 32x. BTW, I scan all burns with KProbe and seldom have C1-average > 0.5 with Verbatim DLP.
Postby Scour on Tue Oct 25, 2005 6:23 pm
I burned all Audio-CDs with the max. speed that the writer can go (up to 52x) and had never problems with the quality.
Sometimes it´s more important to use a lower speed when reading
Postby pranav81 on Fri Oct 28, 2005 2:43 am
I normally burn them at 52X on LG burner on Sony CD-R's.Never had any problems.
::Pranav::
pranav81
Postby SkaarjMaster on Tue May 30, 2006 12:48 pm
I've changed my strategy a bit lately. My default burn speed for music is now 16X with burning at 8X if music is close to or over 80 minutes.
SkaarjMaster
cd burn speed
Postby bicomputational on Fri Sep 29, 2006 10:06 am
I burn at max speed with a Plextor Premium, a Plextor 716 and a Lite-On
52327 with average c1 of .5 using Ty media and 1.5 using Sony media -
no c2. I spot check jitter and have never had any problem. I did tests at
16x and saw no real difference - try burns at different speeds and see if it
matters in your set-up with your media.
bicomputational
Postby SkaarjMaster on Fri Sep 29, 2006 2:48 pm
I'm sticking with 16X and 8X for now, so the music has a better chance of playing in my car stereo. :D
SkaarjMaster
