LG burner, model GCE-8520B, CD's not working in car
Postby warrick on Wed Jun 04, 2003 8:33 am
I have two LG burners, model GCE-8520B installed in the same PC that work OK using the NERO software supplied. The problem I have is audio discs I burn will work on every CD player I have tried except for my car, a 1999 camry with factory fitted player.
I have tried both burners, burning at the slowest speed possible, using disc copy and transferring tracks individually, without success.
Discs burnt by other people do work OK in the car. I have tried using the same software they are using. but it will not recognise the LG burners.
I would appreciate any help or suggestions you might have.
Thanks and best regards....Warrick
warrick
Postby TheWizard on Wed Jun 04, 2003 8:43 am
What discs are you using? The discs burned by other people that work in the car, are they 74 minute or 80 minute discs? Which specific brand/manufacturer? Try to replicate the same discs they use that work in the car.
No, I like women.
Postby warrick on Wed Jun 04, 2003 9:50 am
TheWizard wrote:What discs are you using? The discs burned by other people that work in the car, are they 74 minute or 80 minute discs? Which specific brand/manufacturer? Try to replicate the same discs they use that work in the car.
I am at work at the moment and don't have details to all the disc types. But I have tried the same Sony 80 min discs, burnt by a friend, that worked OK...no luck
Thanks for helping...Warrick
warrick
Postby Scrondar on Wed Jun 04, 2003 4:38 pm
FWIW, I have a '95 Camry that chokes on just about all the discs I burn. I think it's the sub-par head unit they put in the car. On the other hand, my discs play fine on the Pioneer Premier H/U I installed in my Accord. BTW, all discs burned on a 8520B using T-Y media.
Scrondar
Postby jedimc on Fri Jun 06, 2003 4:41 am
try updating the firmware to Version 1.04
and Samsung CD-ROM SC-148T
jedimc
