BUG?no burns on slave drive using Multiple Recording feature
Postby jtan on Sun May 25, 2003 2:55 am
does anyone encounter this problem? i'm currently using two cdwriters and when i do lots of burn, there are cases that my cd-r burn using the slave drive is empty...
jtan
Postby CDRecorder on Sun May 25, 2003 6:04 pm
What is the master drive, and what's the slave? It would probably be nice if they were the same.
Also, update to the latest version of Nero (5.5.10.28, I think) if you haven't already.
Postby jtan on Wed May 28, 2003 2:36 pm
i did a double check, using cdrwin when we constantly do burning of 100 copies, there are still cases of no burns on some CDs... no burn means the CD-R is empty, can still be used, and yet the software reported burn successful... i'm not sure if this has something to do with LTR-48125W's firmware or my drive is getting old after 1300 burns...
jtan
