Blu-ray Rewritable Read-Only problem
Postby JT101 on Sun Nov 13, 2011 8:23 am
Hi
I'm having issues with my blu-ray drive burning rewritable blu-ray media
Drive: LG BT10N HL-DT-ST BD-RE _GBW-T10N
Discs: TDK BD-RE 50GB DL Ver 1.3 1-2X.
Laptop: Lenovo X200T 1.8Ghz, 4Gb RAM, 160Gb Harddrive with plenty of free space
System: Windows 7
The problem is, I do a full erase with the latest InCD, and full format and then use in Windows drag and drop burning. It works absolutely fine, but then after a few times it comes up with this message:
"InCD: Mounting drive D: for read-only access
The disc has been marked read-only by UDF writing software."
So I tried erase and format with Windows. Exact same problem, so it's not limited to InCD.
This is happening with all my discs, and all my discs are new.
If I try then to drag and drop a file, it keeps it as a temporary file to be burned. When I try to burn, it wants to burn the file to disc like a normal burn operation i.e. as if there were no other files, and it were starting from scratch. Except that fails aswell.
Thanks in advance
JT101
Re: Blu-ray Rewritable Read-Only problem
Postby Ian on Sun Nov 13, 2011 2:49 pm
What version of InCD are you using?
Postby JT101 on Sun Nov 13, 2011 5:34 pm
InCD 6.6.5100. The latest as I say
JT101
Postby Ian on Mon Nov 14, 2011 12:06 am
I'm not really sure. Does it happen with 25GB BD-RE discs too?
