Bit-setting in Nero?
Postby compman on Fri Jul 02, 2004 10:31 pm
I cannot find an option to set the booktype in Nero. I'm using a Lite-On LDW-851S. Can anyone help?
compman
Postby burninfool on Sat Jul 03, 2004 3:21 pm
What ver. of Nero are you using?
I use 5.5 and it is located in "More" with Express and the burn tab with ROM.If you use 6 download the latest update because the changelog mentioned it "Improvement of booktype setting for some drives".
Bitsetting
Postby compman on Sat Jul 03, 2004 6:30 pm
I'm using the latest version posted on July 2. The option is nowhere to be found. I don't understand why.
compman
Postby burninfool on Sat Jul 03, 2004 8:46 pm
Re: Bitsetting
Postby rdgrimes on Sun Jul 04, 2004 12:53 am
compman wrote:I'm using the latest version posted on July 2. The option is nowhere to be found. I don't understand why.
It's now moved to the drive properties. (Select Recorder) It doesn't work on many drives. They appear to be using a simple list of supported drives, but so far nobody has posted whether hacking that list will accomplish anything. Probably not.
rdgrimes
Thanks rdgrimes....
Postby compman on Sun Jul 04, 2004 8:54 pm
Thanks rdgrimes, I found it, thanks to your direction. It does work with my drive...Liteon 851s.
compman
