24-bit Analog Recording using Creative Audigy
Postby dforion on Mon Nov 18, 2002 8:46 pm
One CreativeLabs tech-support said the Audigy-1 would not record at 24-bit.
Another tech said it would if I D/L a 24-bit Codec....from Microsoft or somewhere else. I could not find any such thing on Microsoft. Any comments on this???
dforion
Postby Action Jackson on Mon Nov 18, 2002 8:56 pm
I can't be sure about this, but I've read that the first generation Audigy cards had "software emulated" 24 bit recording.
The Audigy 2 was supposed to be true 24 bit.
Action Jackson
Postby dforion on Tue Nov 19, 2002 2:45 pm
Thanks for the info Action Jackson.
My brief contact with Creative Labs has been less than impressive. One tech says I can do this with the Audigy-1, the other says I can't. And the specs on the product are ambiguous because they say "24-bit conversion from Analog to Digital" but also say "16-bit recording @48Khz". This is where I get confused.
With this kind of poor support, if I do end up with a new soundcard, there must be a suitable alternative to the Creative stuff.
dforion
Postby cfitz on Tue Nov 19, 2002 3:30 pm
DFORION, I would suggest reading the following revies as a starting point if you wish to learn more about the Audigy line of sound cards (all from www.tomshardware.com) :
Original Audigy
Original Audigy vs. Terratec DMX 6Fire 24-bit card
Audigy 2
This is an interesting quotation from the last article:
www.tomshardware.com wrote:The Audigy 2 Platinum eX uses the same system as the Audigy Platinum eX, meaning a card and an external rack, but it has some extra technical features that will interest music-makers, especially the fact that it alone supports the ASIO 2.0 standard, and so it can handle recording and processing in 24 bits/ 96 kHz with Cubase VST. The basic Audigy 2 and Platinum only have ASIO 1, so they are limited to 16 bits/ 48 kHz in this respect. What's more, the external rack has been completely redesigned and will look like the Extigy.
The Audigy 2 Platinum eX is due for release early in 2003.
So, despite Creative's first claims that the original Audigy was a 24-bit card (which turned out to be, for all practical purposes, not true) and their follow up claims that the Audigy 2 truly is a 24-bit card, they are now saying that it is the enhanced Audigy 2 Platinum eX being released in 2003 that will finally (this time they really mean it) allow true 24-bit recording?!??! :(
Postby cfitz on Wed Nov 20, 2002 2:44 am
This site has a number of reviews of higher-end sound cards:
http://www.digit-life.com/sound.html
