Best way to save Audio CD's to pc?
Postby SPaulovic on Sat Nov 13, 2004 8:22 am
Hi,
I'm about to save about 20 Audio CD's to my PC. (in order to avoid changing them everytime :D ).
The problem is that i have a lot of cd's that are CD-Extra. (Iron Maiden especially)
Question: What is the best (uncompressed) way to save cd's?
Currently I think about the "CD-Copy" function in Nero, because the music is saved without any compression and the data track is also kept in the image.
Furthermore Nero has this function:
"Read Media Catalog Number and ISRC"
What is it about? I tried to enable it, but then the reading speed dropped to 700 Kb/s and that's very slow.
I pay much attention on audio quality, therefore I don't want to
rip the audio tracks and convert them into wma or mp3.
Can you give me some advice how to solve with my problem?
SPaulovic
Postby hoxlund on Sat Nov 13, 2004 10:41 am
you could also rip them to hard drive using a lossless codec, meaning no loss in audio quality to hard drive
since i always do 192Kbps mp3's i wouldn't be the one to ask how to do this, but you could use an audio ripper like exact audio copy and just load a lossless compression codec
just search on google, it shouldn't be too hard
Postby burninfool on Sat Nov 13, 2004 12:23 pm
The best uncompressed format is WAV,then there are lossless compression formats such as APE or OGG.
I recommend you use CDex to rip and convert.
Postby SPaulovic on Sat Nov 13, 2004 1:54 pm
Thank you for your answers.
As I have a Plextor Premium drive I will use the Plextools Audio Extraction to create .wav files.
Unfortunately this method only extracts the audio tracks.
Does creating an iso image of the cd influence / lower the bitrate or is it the same as with .wav?
SPaulovic
Postby burninfool on Sat Nov 13, 2004 4:42 pm
SPaulovic wrote:Thank you for your answers.
Do you want to extract the video(extras) as well?If so use Windows Explorer to drag and drop to your HD.
Creating an ISO image will result in the same bitrate(1411kbps).
Postby SPaulovic on Sat Nov 13, 2004 5:15 pm
Creating iso files is not a good solution, as there is no error checking.
Now I'm using Plextools with error detection. The audio tracks are
saved as wav 48kHz, 16 bit, stereo files.
This is the best solution, I think.
Again, thanks for the quick advice. :D
SPaulovic
not sure but...
Postby DoWnR on Sat Nov 13, 2004 7:25 pm
I'm not sure but I think using 48kHz wave files to store audio cds on your hdd is useless and a waste of space since CDA are encoded @ 44kHz/16bit/stereo
DoWnR
Postby Spazmogen on Sat Nov 13, 2004 9:19 pm
You can also use a lossless system called SHORTEN.
Basically, you rip the CD to WAV or Bin/Cue and then run shorten.
It's more of a storage/file sharing compression though.
After doing some reading, I see that FLAC has become more popular than .SHN.
Re: not sure but...
Postby SPaulovic on Sun Nov 14, 2004 4:18 pm
DoWnR wrote:I'm not sure but I think using 48kHz wave files to store audio cds on your hdd is useless and a waste of space since CDA are encoded @ 44kHz/16bit/stereo
Yes, you`re right. I ripped the cd to wav. files with 44kHz, 16 bit, stereo.
Surprisingly a ripped track is bigger than a track within an iso file.
The difference is about 5 MB! / audio track.
Nowadays the storage of big wav. files cannot be regarded as a waste of hdd space as the disk capacity increases.
Digital images are also saved in tiff. files to ensure better quality, esp. for printing.
@ Spazmogen
Thanks for doing some research. I rather prefer converting into wav. files
because it's surely much more simple than editing them afterwards.
SPaulovic
Postby pranav81 on Mon Nov 15, 2004 2:25 am
I liked the lossless format of Windows Media Audio.I use Media Player 10 for encoding and play the files using Winamp.
Also anything greater than 192 Kb/s in MP3 is also great and you probably wont notice the difference.
::Pranav::
pranav81
Postby xchagg on Wed Dec 22, 2004 8:06 pm
You can use EAC to rip the the entire CD as a WAV and CUE sheet. Than use Dameon Tools to mount the CUE sheet, and play with your normal media player. This takes up anywhere between 500-800MB per disc.
Or if you want to save space (anywhere between 30-70% of the original CD), just rip the CD with EAC and compress using a loseless codec like Monkey's Audio or FLAC. Use one folder per album. I don't know if it is useful but I also save the CUE sheet of the CD together with the APE/FLAC files.
And of course play back using Foobar2k :)
Puffing away on an antiquated Mitsumi CR-4084 TE > 4yrs old @ 4x :\
Finally got new drives and comp wohoo. Lite-on 52327S and a NEC 2100@2510 lol
xchagg
