Best Quality Burn
Best Quality Burn
Postby mushmouth on Thu May 19, 2005 2:44 pm
Ok I know this has probably been asked a billion times but, here I go:
What is the best (cheap) DVD\CD writer that produces the best quality burn?
I heard that Plextor was pretty good but I'm looking to spend a little less.
Any recommendations?
peace
mushmouth
Postby AirTimid on Thu May 19, 2005 3:08 pm
Subjective question. Alot depends on the type of media you normally use.
AirTimid
Postby mushmouth on Thu May 19, 2005 3:42 pm
I guess to be more specific, which one of these 2 units would provide the best quality burns given that the best/recommended media is used:
Pioneer DVR-109
Sony DWD-26A
thanks!
mushmouth
Postby dodecahedron on Thu May 19, 2005 4:01 pm
Pioneer. no doubt about it.
Postby mushmouth on Fri May 20, 2005 10:38 am
cool, thanks!
mushmouth
Postby burninfool on Sat May 21, 2005 1:19 pm
BenQ.
Again there are many factors(media,firmware,model number,etc) but it consistantly get high marks.
Re: Best Quality Burn
Postby Scour on Wed Jun 01, 2005 5:57 pm
mushmouth wrote:Ok I know this has probably been asked a billion times but, here I go:
peace
For burning CD or DVD?
Postby evanrabby on Wed Jun 15, 2005 6:29 pm
asus crw5232 (asus quietrack). look at write quality tests. nothing else really matters. the aopen 52x was actually the best. new liteon sohr 5239s (all youll find in stores now, 52327ss are out of manufacture now) are terrible, giving c2 errors wherease other burners don't here are some tests:
(btw, plextor gets the WORST SCORES EVER over several media types. why all the hype when they write crappy disks?_)
liteon disc enclosed with sohr writer
sohr write, second old liteon read
sohr 5239s write, old liteon read
evanrabby
Postby Scour on Wed Jun 15, 2005 8:11 pm
Sast, Princo...
Both are very crappy media
Postby evanrabby on Wed Jun 15, 2005 11:01 pm
actually the princo have the best compatibility with hard to read cd players. the higher quality cdr like taiyo yuden dont read well in some older machines... i find middle of the road media does better at wide compatibility.
heres some ritek. look at the numbers .2000 errors in samples is not a crappy disc. but what we're after is look at how the 52327s does so well and the new models the sohrXX do so poor
52327s read and write well
heres brand of ritek i actually use below x 2: sohr 5238s write, 52327s (older model) read
heres bad brand of ritek, 'maxi', see it depends on which brand ritek u use
evanrabby
Postby evanrabby on Wed Jun 15, 2005 11:09 pm
here's cdr labs beloved plextor burner, and some of your beloved taiyo yuden inkjet printable from the same spindle
liteon 52327s burns taiyo well
plextor 40/8/40 new out of box, but old stock i sent back they suk i ordered ten and tested 2 before returning, with your beloved taiyo yuden
and here's the sohr 52328s with same media same spindle read with 52327s. the new liteons have degraded to junk,. just like GM BABY!
evanrabby
Postby dodecahedron on Wed Jun 15, 2005 11:19 pm
evanrabby, it's too bad that you don't post clearly for each scan what drive was the burner and which is the reader. if you can, please edit your posts and add that info.
