Best firmware for Lite-On 52327S?
Postby TheCDBurner on Wed May 26, 2004 2:23 pm
OK, I see Lite-On now has a QS0E58 firmware out. Any better than QS0B?
When QS0C came out, I tried it and the write quality was horrible, everyone here was saying QS0B was better, so I downgraded and it works perfectly. I'm asking instead of just trying it because at the moment I have exactly zero CD-Rs to try...
TheCDBurner
Postby hoxlund on Wed May 26, 2004 2:33 pm
i have a perfect solution for you:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 4133735725
j/k
anyways, its sad to see a company producing new firmware that is worse then there previous one
Postby TheCDBurner on Wed May 26, 2004 2:51 pm
Yeah, I saw that :)
I wouldn't mind having one, but I just got a new DVD burner (NEC 2500), and will be adding at least one more DVD burner soon, if not two (2510, PX-712?).
Still, I like having a fast, high-quality stand-alone CD-RW drive. It'll probably end up stuck in my 2nd PC, if the NEC can burn discs anywhere near as good as the old 1100 (ie, perfectly, even on crappy discs). So far, that 1100 was the best CD burner I've yet seen.
TheCDBurner
Postby hoxlund on Wed May 26, 2004 5:43 pm
well i can sell it to you for $70 and i pay shipping to US
Postby TheCDBurner on Wed May 26, 2004 9:38 pm
Need more DVD burners, not more CD burners :)
But it would be nice.......
No, no. Need DVD burners. But it is a Plex....argh!
TheCDBurner
Postby dodecahedron on Thu Aug 25, 2005 3:51 pm
major bump!
yeah, i know this is history (prehistory?) but i just got my Lite-On 52327S and wanted to ask anyone who still has/uses this drive, what's the best firmware for it? best i mean in terms of writing quality.
there's also R52QS0C, R52QS0E57, R52QS0E58 and R52QS0E5A on the website.
OK i know R52QS0C fixed the "Sub-Channel data" issue (if there ever was one) but worse writing quality than QS0B.
any reports on the writing quality with various flavors of QS0E ?
Postby code65536 on Fri Aug 26, 2005 5:24 am
dodecahedron wrote:R52QS0E57, R52QS0E58 and R52QS0E5A on the website.
To clarify, these are QS0E/QS57, QS0E/QS58, and QS0E/QS5A. These flashers each carry two firmwares.
QS0x is the firmware for the original 52327S.
QS5x is the firmware for the 2nd hardware revision of the 52327S.
So if you have the original 52327S, then these three flashers will all contain the exact same firmware for your drive (QS0E).
If you have the 2nd hardware revision (you can tell by what your current firmware is), then you'll be comparing QS57 with QS58, QS5A, and whatever QS5x firmware you currently have in your drive.
code65536
Postby dodecahedron on Sat Aug 27, 2005 1:27 am
OK didn't know that, i just copied the names from Lite-On's firmware page.
i think i have the orignal drive (1st revision), i think it has QS0B, i'll check as soon as i install it in the computer.
if so, what's better: QS0B or QS0E ?
Postby code65536 on Sat Aug 27, 2005 7:12 am
dodecahedron wrote:if so, what's better: QS0B or QS0E ?
Never used the drive myself, so I can't answer that. :oops: I had just wanted to clarify that there was only one QS0E. ;)
code65536
Postby dodecahedron on Sat Aug 27, 2005 7:41 am
There can be only one! :D
thanks for the clarification.
hey, i thought you were a Lite-On kind of guy, no? (i don't frequent CD-Freaks very often, especially after my run-in with Kenny Shin).
just installed it, my LTR-52327S has QS09. so it's first revision. flashed to QS0B.
thanks for all of your input.
Postby vinnie97 on Mon Aug 29, 2005 1:26 am
I use the latest version (0E) and don't sweat the small error count reporting differences too much. ;)
It certainly makes more readable Verbatim 32X Ultraspeed discs on my Iriver IMP350.
vinnie97
Postby dodecahedron on Mon Aug 29, 2005 3:12 am
i was wondering:
here's what a CDSpeed Disc Quality scan looks like. see below.
look at the read-speed curve. is it supposed to look like that?
i don't remember ever seeing such a curve.
but then again i guess most people with a Lite-On CDRW scan with KProbe and not CDSpeed.
same media as above, burned at 16x CLV
brand: Verbatim DataLife Pastel Disc
type: CD-R, 700MB
speed rating: 48x
ATIP: 97m24s01f Taiyo Yuden
blank capacity: 703 MB, 79:59:72
drive, fw: Lite-On LTR-52327S QS0B
burn speed: 52x (maximum)
Postby MediumRare on Mon Aug 29, 2005 7:38 am
I've seen similar behaviour in a transfer rate graph when there was some activity on the other drive on the same IDE channel, e.g. when listening to a CD while doing the test.
I haven't tried it with a quality scan- I do use KProbe for that. 8)
Postby dodecahedron on Mon Aug 29, 2005 8:41 am
no, when i did those scans the computer was doing nothing but scanning.
Postby Bhairav on Wed Aug 31, 2005 10:14 am
Dodeca, try a CDSpeed transfer rate scan. The Disc Quality test does NOT show a readback scan, see below:
Oh, and use QS0B. Works fine for me, QS0E was better with 24X CDRW discs though.
Postby dodecahedron on Wed Aug 31, 2005 10:37 am
Bhairav wrote:Dodeca, try a CDSpeed transfer rate scan. The Disc Quality test does NOT show a readback scan, see below:
how do you mean "does not allow a readback scan" ?
it does show it but it's weird!
Bhairav wrote:Oh, and use QS0B. Works fine for me, QS0E was better with 24X CDRW discs though.
what do you mean? that burn quality on 24x CDRWs was better with QS0E ?
how about other media ? CDR? 32x CDRW ?
Postby Bhairav on Wed Aug 31, 2005 11:24 am
I don't think that the DQ test is showing a readback scan... it seems to be some sort of OPC readback maybe? Look at those dips..
QS0E allowed me to burn on my 24X Verb CDRW discs. They did not burn at all in QS0B, but the CDR burning was waay better with 0B.No C2 spikes, which were prevalent even with old TY media on OE. Haven't tried any 32X CDRW discs as yet.
Postby dodecahedron on Wed Aug 31, 2005 12:17 pm
well, i burned 10x and 32x Verbatim CD-RWs no problem with QS0B.
haven't tried out 24x Verbatims.
Postby vinnie97 on Thu Sep 01, 2005 1:34 am
burning wasn't the problem for my 32X Verbatims, but playback on a standalone unit certainly was until I snatched QS0E...it's too bad Lite-On didn't take the best of both firmwares and release an "F."
vinnie97
Postby dodecahedron on Thu Sep 01, 2005 4:12 am
i gather you've burned Audio CDs.
i burned data.
Postby dodecahedron on Thu Sep 01, 2005 9:43 am
here's a data backup i've made on a 32x Verbatim CD-RW disc.
i don't know if these are good or bad results.
BTW this is a virgin disc (first burn ever on it).
Drive Type = CD-RW
Disc Type = ULTRA SPEED CD-RW 32X
Material = Phase Change
Lead In = 97:34:25
Lead Out = 74:43:00
Nominal Capacity = 656.40MB
Manufacturer Maybe = Mitsubishi Chemicals Corporation
SMAR
Postby Bhairav on Fri Sep 02, 2005 12:14 am
Give it a full format, and try a CDSPeed Create Data Disc test. Scan that and see..
