Best Drive for CD ripping
How fast is too fast?
Postby Albinoni on Fri Jan 28, 2005 9:55 am
Whats the best DVD/CD-ROM drive for ripping audio CD's. I'm also a member of another couple of forums called "CDR-Info" and "CDR-Labs", and have heard mixed opinion on different drives. I heard that the best drives for ripping were Liteon, Asus and Plextor, but overall Liteon came out on tops for audio cd ripping due to its fast ripping speed. Then some said that Asus drives were the best for ripping. Also is it true that Asus optical drives are very quiet.
Albinoni
Plextor, Plextor, & Plextor somemore!
Postby steelly on Fri Jan 28, 2005 11:50 am
I have the Plextor 712A, and it rips everything fast and quitely.
Read the reviews here and at CDFreaks.
steelly
Re: Best Drive for CD ripping
Postby Bhairav on Fri Jan 28, 2005 1:30 pm
Albinoni wrote:Whats the best DVD/CD-ROM drive for ripping audio CD's. I'm also a member of another couple of forums called "CDR-Info" and "CDR-Labs",t.
You ARE on CDRLabs ;)
Postby burninfool on Fri Jan 28, 2005 5:47 pm
I recommend a Lite-On because they're cheap and fast but not quiet.
BTW...Lite-On drives can defeat most CD protection and you can use KProbe to check for errors on CD-R.
Postby Scour on Fri Jan 28, 2005 7:25 pm
Postby hoxlund on Sat Jan 29, 2005 11:22 am
whatver drive you get just make sure it can do audio caching and can do an accurate stream
also for ripping id recommend exact audio copy:
http://www.exactaudiocopy.de/
Postby MediumRare on Sat Jan 29, 2005 1:27 pm
hoxlund wrote:whatver drive you get just make sure it can do audio caching
Actually it would be preferable if the drive did not cache audio- caching just makes it harder to confirm proper reading. EAC is my choice for CD-ripping too. :D
Postby unclebud on Tue Sep 06, 2005 2:27 pm
free is always good? posted an update that references the mad dog cdrom that's free after rebate in the hot deals forum
unclebud
Postby assalychris on Thu Sep 08, 2005 3:35 pm
the folks at http://www.ubernet.org/ recommend the Plextor PlexWriter Premium http://www.plextor.com/english/products/Premium.html
now these guys take music ripping so seriously I doubt they may be wrong.
assalychris
