I used Backitup to perform a system partition backup to dvd+r. Popups told me that compression could not be used and verification might fail since I was backing up the system drive. The backup took 6 dvd+r to backup the partition that had 16gb of 25 gb used. 2 of the 6 discs failed verification.
Is this normal or is there a way to get compression and verification to work on the windows partition?
Does backitup backup the empty space on the drive?
Is there a way to make sure that I have a viable backup short of restoring it to another hard drive?
Will the nrestore program fit the restoration to a smaller or larger partition?
Thanks for any clarification
Woody Lane
