cd aux audio connecter
Postby cha on Fri Jun 20, 2003 2:24 pm
was having problems with the sound from my pc
feedback on speakers when i turned up the rpm ,
on my volcano 9
i resolved this problem by removing the cdrw analog out
connector to the mobo
could anyone tell me if this needs to be connected
newbie
cha
Postby David on Fri Jun 20, 2003 6:07 pm
If your talking about disconecting the audio cable it isn't needed. Unless you plan on playing music cd's on your cdrw drive and listen to them on your speakers.
David
Postby blakerwry on Sun Jun 22, 2003 4:33 am
The analog audio cable is used when the CD drive is physically playing an audio CD. The drive plays the disc just like a walkman would and outputs line level analog sound to the soud card where it can be amplified and/or passed to the speakers.
You may find that simply muting the CD output in the windows mixer will fix the problem as well.
You don't need the cable, CDs can be read digitally and a media player such as winamp or WMP can play the music.(This is at the cost of a higher CPU utilization and more CD drive noise)
blakerwry
