Audio + Data
Audio + Data
Postby M@m4eto on Wed Apr 16, 2003 1:47 pm
I need to make couple disks with audio and data. I tried to achieve it with Nero, but when i recorded it it was the data first and then the tracks. I tried it again on a cd-rw but it was the same.
I looked at Avril (Let's go or something like that) there they have than the thing that i want!!!with something called CD - Enhance.where can i find it
M@m4eto
Postby Matt on Wed Apr 16, 2003 2:01 pm
It sounds like you were using the traditional mixed-mode cd which puts the audio after the first data track. You need to use "CD-Extra" which makes two sessions, the first containing all of your audio tracks, and a second session containing the data track. If I remember correctly red-book spec doesn't include multisession so the data track is disreguarded on normal audio players.
Matt
Postby Inertia on Wed Apr 16, 2003 2:13 pm
Yes, Matt is correct. Enhanced CD is the same as CD Extra.
Inertia
Postby M@m4eto on Fri Apr 18, 2003 6:30 am
Thanks.
M@m4eto
