Rahul wrote:I am using the windows flash that i downloaded from the asus website:
http://www.asus.com.tw/support/download ... =CRW-5224AI tried it again, but its still coming up with the same error.
How do I get the DOS version, and from where can i get MTKFlash?
Thanks for ur help
Rahul
PS: i used the search function on how to do the above and its didnt return with any results
Don't worry about the faulty search function. It's kinda screwy
![:wink:](http://cdrlabs.com/forums/images/smilies/icon_wink.gif)
. Ian has put up a sticky in the CDR/RW form, mentioning that the search function is down.
Better than MTKFlash is MTKWINFlash, which works in Windows, rather than in DOS like MTKFlash. Get it here:
http://digi.rpc1.org/mwf.htm
Lemme try getting my hands on the binary version of the firmware. Gimme a couple of days for that.
Oh and btw, is your drive malfunctioning in some way, that you wanna update your firmware? If it's working fine, let it be!
