Any way to lower CD read speed?
Postby TheCDBurner on Fri Jul 09, 2004 4:18 pm
Hi all, I've got a CD-R sitting here that was burned with a POS buner (ie, Optorite DD0401) and am having trouble reading back the disc.
Any util's that can set the CD read speed to a lower value, hopefully then I'll be able to copy the disc.
My CD-R software is CopyToDVD (which has BlindWrite, but I don't see anything that can cap BW's read speed).
I know Nero 6 has a feature to do this, but I don't have Nero 6 (nor do I want it; it's as buggy as Windows). Any freeware apps I'm missing?
TheCDBurner
Postby dhc014 on Fri Jul 09, 2004 4:20 pm
I listed all of the ways that I know of here: Speed Control Utilities
You can try Nero DriveSpeed or CDBremse if there is no utility intended for your drive from the manufacturer.
dhc014
Postby TheCDBurner on Fri Jul 09, 2004 4:25 pm
Ah! Cool, thanks!
I was just on the CD Speed page and didn't even see DriveSpeed; I thought that was just part of Nero 6!
Weird; UltraISO made a CD image of it perfectly. Now too see if the data's ok (it skips bad sectors, sorta like CloneCD).
TheCDBurner
Postby TheCDBurner on Fri Jul 09, 2004 4:26 pm
Wow.
The UltraISO image WAS perfect, no speed cap needed. Sigh...I hate computers....
TheCDBurner
Postby OptoRite on Fri Jul 16, 2004 1:54 pm
Hi TheCDBurner,
If you are having problems with the burner, OptoRite can replace it as it is still under warranty. If you would like to replace it, please contact me at support@optorite.com.
Thank you,
OptoRite Support
OptoRite
Postby TheCDBurner on Fri Jul 16, 2004 9:03 pm
The problem is the burners write quality, or lack there of. Unless you've got the burner to actually write CDs and DVDs WELL, I'll stick to using my Lite-On and NEC drives.
TheCDBurner
