Any way to fix a bad flash on a Delta OIP-DV1200A Drive
Postby Viper on Sat Jan 18, 2003 10:24 am
I know big mistake but when I flashed thsi bad boy it died and now I get nothing. Any way I may be able to fix this?
Viper
Viper
Postby cfitz on Sat Jan 18, 2003 12:48 pm
Have you read this?
http://www.sysopt.com/userreviews/dvd/r ... A_12x.html
Apparently the drive uses a mediatek chipset, so if you can find a copy of the original firmware (you did back up the firmware before flashing, didn't you?) then you may be able to boot to DOS and use mtkflash to recover the drive. If you don't have the firmware, try some of the links given on the page I referenced above. I would also normally recommend this:
http://forum.firmware-flash.com/dl_firm ... load_id=70
But their links to the firmware are dead.
From what little I've seen, this drive does not come highly recommended.
Postby Viper on Sat Jan 18, 2003 1:02 pm
cfitz wrote:Have you read this?
Thanks, got it to recover finally........
Viper
Viper
