All kinds of crazy DRU500A problems! Please Help
Postby Stereodude on Thu Nov 14, 2002 1:58 am
I got my DRU500a from Dell yesterday for $247 shipped. Apparently now I'm paying for my good deal in dead media.
I was able to burn an audio CD-R with no problems yesterday. Tonight I started on DVD-R, DVD+R, and DVD+RW.
DVD-R (Khypermedia 1x blanks):
Won't simulate correctly with Nero, Don't burn correctly with Nero (latest version), Don't burn correctly with Veritas Record Now
They all stop at the same point. Nero always turns back the same error.
Code: Select all
8:15:21 PM   #25 SCSI -1135 File Cdrdrv.cpp, Line 1388
   SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x027A0000
   Status:     0x04 (0x01, SCSI_ERR)
   HA-Status   0x00 (0x00, OK)
   TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
   Sense Key:  0x03 (KEY_MEDIUM_ERROR)
   Sense Code: 0x0C
   Sense Qual: 0x08
   CDB Data:   0x2A 0x00 0x00 0x02 0xBB 0x00 0x00 0x00 0x20 0x00 0x00 0x00
   Sense Data: 0xF1 0x00 0x03 0x00 0x02 0xB2 0x2E 0x12
               0x00 0x00 0x00 0x00 0x0C 0x08
Here's what Veritas spit back:
Code: Select all
Disc Write Error  -  Sense:03 ASC:0C ASCQ:08 (Command:2A)
Sony DVD RW DRU-500A (Q:) ATAPI  (1.0d)
PX.DLL                   -          1.1.0.350
PXMAS.DLL           -          1.5.0.105
PXWAVE.DLL        -          1.2.0.85
PXWMA.DLL        -          1.0.0.2
OLEAUT32.DLL     -          3.50.5016.0
MSVBVM60.DLL    -          6.0.92.37
MSCOMCTL.OCX   -          6.0.88.62
MSCOMCT2.OCX   -          6.0.88.4
PXHelp20.SYS       -          2.2.38.0
I've ruined 2 DVD-R's so far and have tried to simulate on the rest. I have tried both firmwares with no luck.
DVD+R (Verbatim 2.4x DVD+R):
Can't simulate with these and I have no idea why. They burn all the way to 100% fine and then quit with the following error in Nero
Code: Select all
9:14:32 PM   #18 SCSI -1066 File Cdrdrv.cpp, Line 1184
   Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
   Sense Code: 0x24
   Sense Qual: 0x00
   CDB Data:   0x5B 0x01 0x01 0x00 0x00 0xFF 0x00 0x00 0x00 0x00 0x00 0x00
   Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
               0x00 0x00 0x00 0x00 0x24 0x00
9:14:32 PM   #19 SCSI -1176 File Cdrdrv.cpp, Line 1184
   Sense Code: 0x72
   Sense Qual: 0x04
   CDB Data:   0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
               0x00 0x00 0x00 0x00 0x72 0x04
The error that you can see in Nero window is something about illegal mode, unable to close disc. I've tried multisession w/ leave disc open, DAO w/ finalize. No dice.
I did not try Veritas.
DVD+RW (Verbatim 2.4x +RW):
Works fine in nero. Haven't tried Veritas.
I'm running a AMD Athlon 1400 Win XP SP1. I previously had a HP 9900i in this PC with no problems.
I see other people have managed to get Khypermedia to work correctly. I'm going to try the drive in another PC tomorrow.
Stereodude
Stereodude
Postby VEFF on Thu Nov 14, 2002 3:01 am
1) If you upgrade your firmware to 1.0d, it will solve most media issues.
2) Try Stomp RecordNow Max 4.5
3) If you use Veritas RecordNow 4.5, be sure to enable
Lossless Linking in the options.
Since getting my DRU-500A about 15 days ago, I have successfully burned the following:
TDK 2X DVD-R
Sony 2.4X DVD+RW
Philips 2.4X DVD+R
KHypermedia 1X DVD-R
DVDPro 1X DVD-R (silver top)
Princo 2X DVD-R (white glossy top)
Princo 1X DVD-R
Prodisc 2X - the only brand I had any problems with (one batch worked; the white inkjet printable ones didn't work, but that was with the old firmware). Just got a sample today; will test it tomorrow.
NOTE: Prodisc just discontinued these, because they weren't happy with the quality...
I did have a few coasters with a few DVDPro when I first used RecordNow, but that was because I played with the Lossless Linking setting. I then burned the same media again (with the old firmware at the time) and all went fine. Have burned several since, without any problems.
Burners only:
Pioneer DVR-115D
Pioneer DVR-111D
Plextor PX-716A TLA0304
Plextor PX-716A same TLA
LiteOn 52246S 52X CD-RW
LiteOn 52246S (another)
LiteOn 52327S 52X CD-RW
TDK 40X USB 2.0 CD-RW
TEAC CD-W540E 40X CD-RW
VEFF
Postby sonyman on Thu Nov 14, 2002 3:11 am
Veff- Take a closer look at his error logs. He already has 1.0d.
-Scott
Gigabyte GA-8KNXP
Intel Pentium 4 3GHz
1024MB PC3700 DDR @400MHz CL2
ATI Radeon 9700 Pro
Sony DRU-500A
Lite-On LTR-52327S 52x32x52
sonyman
Postby Stereodude on Thu Nov 14, 2002 9:12 am
VEFF,
I have 1.0d. The same problems occur with and without it.
Here's two screenshots from Nero to show the lack of a simulate option on DVD+R and the error that I get on the end of Verbatim Blanks.
I guess I'm going to Best Buy to buy a bunch of different brands of -r and +r to try.
Stereodude
Stereodude
Postby Stereodude on Thu Nov 14, 2002 9:19 am
VEFF wrote:3) If you use Veritas RecordNow 4.5, be sure to enable
Lossless linking is and has been enabled.
I'm trying one of the Verbatim 2.4x +R blanks in the drive now (but I'm expecting a frisbee).
Stereodude
Stereodude
Postby Stereodude on Thu Nov 14, 2002 11:42 am
Stereodude wrote:I'm trying one of the Verbatim 2.4x +R blanks in the drive now (but I'm expecting a frisbee).
Stereodude
I have found my first sucess on DVD+R.
Veritas RecordNow 4.5 on a Verbatim 2.4x DVD+R blank was sucessful with default settings with firmware 1.0d. I started another blank Verbatim 2.4x DVD+R in Nero to see if the firmware will solve the Verbatim DVD+R problem. I will check it when I get home.
Veritas fails burning and Nero fails simulations on Khypermedia DVD-R at 1x with firmware 1.0d. The firmware did not solve this one.
Stereodude
Stereodude
Postby VEFF on Thu Nov 14, 2002 12:11 pm
sonyman wrote:Veff- Take a closer look at his error logs. He already has 1.0d.
-Scott
Thanks for pointing that out Scott.
stereodude:
I have only used Nero once for my DRU-500A to be honest, so I have no personal experience in terms of how reliable it is with the DRU-500A, and I can't give you any feedback there.
Side note: I don't use Nero for the following reason:
Nero cost me about 8 "semi-coasters" (at $5 and up a pop back in March 2002) with my previous DVD burner (they play in my Apex, but NOT in my Xbox or Toshiba DVD changer).
Nero STILL doesn't seem to have fixed this file system bug with their 'DVD video' compilation type.
It was in their changelog as having been fixed, but if you look at the compilation type's properties/tabs you'll notice that the UDF filetype tab (they said they fixed the UDF bug) isn't even there (even in 5.5.9.17)!!!
I also tried DVD-ROM UDF/ISO compilation type (with older versions of Nero) and got the same results.
Thank God I have more than one DVD player; if I only owned the Apex, I might still be using Nero for DVD video discs.
I switched to Stomp RecordNow Max (4.0 at the time) and haven't looked back - the DVD video discs it creates play in all three of my home DVD players.
Maybe it really is my players, but in any case, Stomp discs work in all of them, so I will continue to use it...
I guess you either got a different batch of KHypermedia or a bad batch.
I'll tell you what: I will burn a data DVD-R disc with Nero tonight ( no DVD video; see above why). This way we can see if it is the media or the software.
I am leaning toward the cause being your batch of media (I mentioned that different batches of Prodiscs gave me different results - the discs had changed in appearance from the previous design).
Let's nip this in the bud.
Burners only:
Pioneer DVR-115D
Pioneer DVR-111D
VEFF
Postby Lux_a on Thu Nov 14, 2002 1:17 pm
nero 5.5.17.1 has a bug - closing session for all DVD+R's on Sony.
downgrade to 5.5.17, that works ok or wait for next update.
5.5.17.1 was silently released on nov,7 where original 5.5.17 was released on nov,1
check vcdhelp.com forum, i had a thread there on this issue.
Lux_a
Postby Stereodude on Thu Nov 14, 2002 1:28 pm
Lux_a wrote:nero 5.5.17.1 has a bug - closing session for all DVD+R's on Sony.
Thanks for the tip. This will save me from some gnashing of teeth.
Stereodude
Stereodude
Postby Stereodude on Thu Nov 14, 2002 1:38 pm
Ok, so this should resolve all the problems except the K Hypermedia fiasco. Now to return the other 5 pack to OfficeMax and find some other good inexpensive blanks locally.
Stereodude
Stereodude
DVD+R Error and Nero
Postby Nemesis on Tue Dec 03, 2002 8:38 pm
I've been experiencing these errors with Nero and Verbatim DVD+R discs for the last few days.
Right now I am closing the track and then the disc with DVDDecrypter and the discs work fine. It appears that all the data is on the disc after I closed the session. A work around for now, but I'd like to know if it nero's problem or a hardware problem.
Just an FYI if you need to use need to use Nero to burn
Nemesis
Re: DVD+R Error and Nero
Postby Stereodude on Tue Dec 03, 2002 9:23 pm
Nemesis wrote:I've been experiencing these errors with Nero and Verbatim DVD+R discs for the last few days.
Nero problem. Read the post two above yours.
Stereodude
Stereodude
Nero
Postby Nemesis on Tue Dec 03, 2002 9:54 pm
My Nero About says 5.5.9.17 and the archive i installed from is nero55917.exe and it won't burn DVD+R, unless they did not change the name of the release file and the about for 5.5.9.17.1 which they probably didn't. I am searching for a good nero55917.exe dated before nov7 hopefully i can find one.
You said you used Record Now 4.5 is that record now max 4.5? I just been to be able to burn these nero would be cool, but I don't care as long as I don't have to use two programs.
Nemesis
COPY DVD
Postby vdepina on Fri Dec 06, 2002 10:57 pm
Can someone tell me which program copy a hollywood movie?
I have DVD+RW Sony DRX500UL External
thanks
i am computer tech with a lot experiences
vdepina
Postby Kennyshin on Sat Dec 07, 2002 11:06 am
Copying DVD movie titles? DVDxCopy which is rather expensive and CloneDVD which will be released next year. Anyway, most Hollywood movie titles use discs over 4.7GB.
Kennyshin
Postby Kennyshin on Sat Dec 07, 2002 11:27 am
Kennyshin
DRU500A Problem
Postby vdepina on Sun Dec 08, 2002 9:14 am
my name is Virgil Depina
everyone who has problem with DRU500A, I think I can help
I have external one DRX500UL, Installed on my Sony Vaio 750, 20GB, 256 Ram. I dont have any problem yet, i did install Nero but I had to updated to 5.5917 is working good, please try to burn on DVD+RW first,
DVD+R sony, and i did install EZCD Creator 5 platinum it did not recognize my DVD drive I had to get updated from Roxio, now its working fine, please go slowly dont try to do everything in one day, i did not updated my drive to 1.0f yet if someone could tell me where I can get this update I will apreciate it, I am still working with the drive I like it so much
especially for big storage, I will try the 9.4 GB media, is anyone have tryied yet? please let me know
thanks
vdepina
