However someone has accidentally uninstalled Direct CD
I need to reinstall Direct CD. Can I get this as a free download somewhere? I think the version number was 2.5d - this is a guess however, maybe someone else knows the exact version I need.
As it worked fine on my PC should I reinstall the original version of Direct CD or would an update work equally well?
PS: Where can i get an original (s/h) CD-Rom of Easy CD Creator 3.5c with Direct CD in the UK.
And If in the future i decided to update easy CD creator and direct CD would there be any back-compatability issues!
Thanks in advance.
