I have a LG-4082B DVD burner with A206 firmware.
I have no issues with burning DVD's on this burner (both movies and data backup seem fine). When I try to make an audio CD-R, it does not play properly on my CD player. I am using Roxio to burn the CD-R and although it burns successfully, I getting hissing noise when I play it on my player.
- i know its not the problem with the player because it does play other CD-R's that I burned using my older CD burner.
- i tried with different CD-R media with the same result.
- i tried with different audio files with same result.
Any help on the problem would be appreciated.
