SATA Card That Works With Optical Drives?
Postby Ian on Mon Jul 02, 2007 3:58 pm
Can anyone recommend a PCI SATA card that works with optical drives? It only needs like 2 or 4 ports.
Postby Ian on Mon Jul 16, 2007 11:07 am
No one?
Postby SithTracy on Mon Jul 16, 2007 4:17 pm
I have read that the Adaptec 1210SA and 1220SA cards support ODD very well. But Adaptec cards can be pricey... There is one from Silicon Image that supposedly works well too, I just can't recall the chipset... in the office right now so my searches are "monitored"
Postby john on Tue Jul 31, 2007 8:26 pm
The Silicon image 680 (680A ?) chipset suppofts optical drives, I'm using one with a MSI 865 chipset motherboard
john
Postby Ian on Tue Jul 31, 2007 8:29 pm
Thanks john. Do you know of any manufacturers or models that use it?
Postby Ian on Tue Jul 31, 2007 8:30 pm
Postby SithTracy on Tue Jul 31, 2007 11:03 pm
A guy I work with said he got ODD to work with this (I think it needed a firmware update):
Syba SD-SATA-4P (Based on Silicon Image SIL3114)
NewEgg.com has it.
Postby frank1 on Thu Sep 27, 2007 5:14 am
Plextor America lists some mainboards & PCI boards which they have tested as compatible with their SATA burners:
http://www.plextor.com/english/support/ ... ility.html
Fore example here for the PX-755SA:
http://www.plextor.com/english/support/ ... isting.htm
you can find some « Supported PCI Boards » and « Not Supported PCI Boards »
At the moment I use without problems a Plextor PX-760SA burner
connected to this Promise SATA300 TX2plus PCI card
on an an ASUS P4P800-E Deluxe mainboard.
PROMISE Sata300 TX2plus
This PCI card has 2 Serial ATA connexions + 1 Ultra ATA/133 connexion
[URL=http://imageshack.us]Image
http://www.ldlc.com/fiche/PB00030071.html
[/URL] 59,50 €
frank1
Postby Ian on Thu Sep 27, 2007 8:26 pm
I just dusted off my old game machine and used that. It's got an Intel chipset that works fine with all optical SATA drives.
Postby JASTECH on Thu Oct 18, 2007 10:44 pm
Ian, I would recommend Adaptec, 3ware, LSI, Acera or Intel. The lower end cards may give problems in compatibility with some optics and HD's as well.
JASTECH
